PUNDITIN FAQ
Skip to main content
Print
Enabling 2FA
Enabling Two-Factor Authentication (2FA) adds an extra layer of security to your accounts, beyond just the password.
By enabling 2FA, you ensure that even if someone obtains your password, they would still need the second factor—something only you have—to access your account.
Always make sure to keep a copy of the  backup Key stored in a safe place. It is a critical piece of information used to regain access to your account or encrypted data if the primary method of access is unavailable.  If you lose access to your phone or the app generating your authentication codes, a backup key allows you to bypass the 2FA mechanism to securely access your account.
To enable 2FA:
1- Go to the dashboard and click on the security option
or
2- Go to your profile name from the top right and select security
Enable 2FA and follow the instructions.
